Downwash77 Posted March 3, 2017 Share Posted March 3, 2017 I finally got my brat running, webber 32 36 running rich, any ideas why? Thanks in advance Link to comment Share on other sites More sharing options...
87subbomber Posted March 3, 2017 Share Posted March 3, 2017 running rich id check jet sizes in said 3236. when is it running rich? idle? part throttle? full throttle? should be 140/140 mains, 170 primary air, 160 secondary air corrector, 50 main idle 55 secondary idle. f50 emulsion tubes. then lean it out. Link to comment Share on other sites More sharing options...
Sapper 157 Posted March 3, 2017 Share Posted March 3, 2017 (edited) On 3/3/2017 at 12:32 AM, Downwash77 said: I finally got my brat running, webber 32 36 running rich, any ideas why? Thanks in advance+1 for making sure you have correct jets.Look into this link... there should be a trouble shooting guide near the bottom http://www.ultimatesubaru.org/forum/topic/161649-ea81-weber-conversion-writeup/?do=findComment&comment=1347335 Edited March 3, 2017 by Sapper 157 Link to comment Share on other sites More sharing options...
Downwash77 Posted March 3, 2017 Author Share Posted March 3, 2017 It's running rich at idle, haven't gotten any further then that, the amount of fuel seen coming out of the primary venturi looks to be about five times the amount coming out the venturi on my proper running wagon. Fuel pressure is correct. Whom is best to call about replacement jets if these are incorrect, thanks. Link to comment Share on other sites More sharing options...
Downwash77 Posted March 6, 2017 Author Share Posted March 6, 2017 After removing my carb I discovered I few things, the fuel in the bowl was very old, (residual gas in lines left after pumping tank dry), a vacume leak(certainly dosn't help matters) and lastly the float was a bit high. Thanks 87 bomber for the jet size verification it was essential to eliminate that question. The car runs mint now! 2 Link to comment Share on other sites More sharing options...
