Jman1991 Posted March 3, 2017 Share Posted March 3, 2017 I have had a 1993 Loyale for the last three years. the engine temp gauge will barley move I replaced the thermostat and now it goes up a bit more but nowhere close to the half way mark. what could be causing this! also the heater barley works Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
DaveT Posted March 3, 2017 Share Posted March 3, 2017 Have to measure the head temp with a real thermometer. The dash gauges are notoriously not calibrated. I have had more than one of each of the following: Normal temp reads as about 1/8th scale, 1/4 scale, 1/2 scale. By scale I mean where the red starts is full scale. They have on the other hand, been very consistent, so once I know where normal is for that car, I know it's normal. The heater may be not working well if the core is blocked, or if the blend doors are not working correctly. Check the temp of both of the heater hoses - better still, the pipes right where they come through the firewall, if you can sneak a sensor in there. Do this after a drive, put the heater on heat, with the fan on high, and on low. Quote Link to comment Share on other sites More sharing options...
Jman1991 Posted March 3, 2017 Author Share Posted March 3, 2017 thanks Dave I will do that. what temperature reading should a properly running engine have so I know what to look for when I measure the head temp. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 3, 2017 Share Posted March 3, 2017 About 200 F GD Quote Link to comment Share on other sites More sharing options...
Jman1991 Posted March 3, 2017 Author Share Posted March 3, 2017 thanks GD Quote Link to comment Share on other sites More sharing options...
