new rear spring coils
Hello,
i need to replace my rear spring coils on a Leone Superstation Turbo (1987) because they are split in two.
All the spare parts I found are out of production.
Can you please tell me if anyone makes matching spring coils ?
May be from an other car ?
I wanna keep the rear at the same hight as i am to install the SJR 2'' lift and dont wanna add additional lifting.
thank you !
Franz
In that case, there is a year of honda accord front springs that fit.  Here is the link for the writeup: http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/
If you do those, you may want to find them used.  I think I ended up having to cut 1.5 to 2 coils when I used new ones on my 87 GL Coupe, and it still rides a LOT stiffer.  But, they are more readily available.
  • Like 1
  On 3/6/2017 at 11:15 PM, scoobiedubie said:
Why not just use loyale spring/shocks because it raises the back end by about and inch or two.  It makes it look a lot classier.
Because they are no longer available new, and who knows how worn a used spring is going to be.
  • Like 1
