Wildem Posted March 8, 2017 Share Posted March 8, 2017 This car has a cable clutch. After replacing the clutch, flywheel, release bearing, and clips there is no pedal and the clutch is not useable. I've tried tightening up the cable but it does nothing. It's like there's too much room between the bearing and the clutch it just doesn't meet. (Clutch is 100% in correct way engine was just pulled to confirm) Link to comment Share on other sites More sharing options...
987687 Posted March 8, 2017 Share Posted March 8, 2017 (edited) There really isn't much to go wrong in there, honestly. Have you confirmed that pushing the clutch pedal is moving the clutch fork? Did you put the throw out bearing clips in properly to hold the throwout bearing to the clutch fork? It is possible for clutch forks to crack/break in half, that didn't happen, did it? Edited March 8, 2017 by 987687 1 Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 8, 2017 Share Posted March 8, 2017 The cables can break. Not often, but ensure the end is operating properly. Is the top of the clutch fork moving properly but not engaging the clutch? 1 Link to comment Share on other sites More sharing options...
Wildem Posted March 8, 2017 Author Share Posted March 8, 2017 Yes the clutch pedal will move the fork but not the pressure plate it just seems like it doesn't meet Link to comment Share on other sites More sharing options...
Wildem Posted March 8, 2017 Author Share Posted March 8, 2017 Fork didn't look cracked when I cleaned it up along with the knob in the tranny Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 8, 2017 Share Posted March 8, 2017 If the fork is okay, the likely culprit is either the throwout bear clips or the retainer clip on the back of the clutch fork. (Or that it got bumped somehow and popped off the pivot point. At this point I would disconnect the clutch cable and grab the top of the clutch fork to see if you can feel whats going on. Is it attached to the pivot point or loose and flopping around? Does it seem to side and push as it should or just flex? If it's the fork in some way you'll probably feel something. Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted March 8, 2017 Share Posted March 8, 2017 Look through the old parts and check to see if you find two throw out bearings. Lol Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 8, 2017 Share Posted March 8, 2017 Didnyou adjust the cable so you have 1/4" of free play at the end of the fork? Link to comment Share on other sites More sharing options...
moosens Posted March 8, 2017 Share Posted March 8, 2017 (edited) Have to adjust that cable way back now that you have the fresh , thicker guts in there. I also freaked out same as you and it was the end of a tiring day etc .... so I thought about it and came back the next day and adjusted that link way the F back and it then acted appropriately. Now that it's spring I need to fine tune my hill holder or elinate it. As mentioned - 1/4" or is it 1/8" ? You'll get it. Take your time. Edited March 8, 2017 by moosens Link to comment Share on other sites More sharing options...
Wildem Posted March 10, 2017 Author Share Posted March 10, 2017 No because when I seperated the engine a second time I added two brand new j clips. And I tried adjusting the cable all the way back but it gets a half clutch and it sticks down. New cable? Link to comment Share on other sites More sharing options...
Wildem Posted March 10, 2017 Author Share Posted March 10, 2017 Could the cable be too stretched out? The old clutch was driven until the rivets popped. Link to comment Share on other sites More sharing options...
987687 Posted March 10, 2017 Share Posted March 10, 2017 The cable doesn't really stretch, and if it did, that's the point of the adjustment.You didn't remove the pivot ball and put it in the wrong hole on the transmission, did you?Are you sure you're adjusting the clutch correctly. When the pedal is up (pull it back up if it sticks down) there should be between 1/8" and 1/4" play at the clutch fork. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 10, 2017 Share Posted March 10, 2017 No because when I seperated the engine a second time I added two brand new j clips. And I tried adjusting the cable all the way back but it gets a half clutch and it sticks down. New cable? What about the retainer clip on the clutch fork? New or re-used? Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 10, 2017 Share Posted March 10, 2017 I've had a somewhat similar issue with new clutches in the past. Try adding some washers under the adjusting nut to pull the fork back further. Another thing to check is make sure the cable sheath is set properly into the bracket on top of the trans. If you have some thick o-rings you can add an o-ring around the rubber mount on the sheath to help pull the sheath back a little further away from the fork. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 10, 2017 Share Posted March 10, 2017 What clutch kit did you use? GD Link to comment Share on other sites More sharing options...
