DaveT Posted March 9, 2017 Share Posted March 9, 2017 Later tonight I'll be where I can try to find a fsm online. The fuses look good... by testing with a voltmeter? You cannot tell by visual inspection. I have had failed fuses that look just perfect visually. Quote Link to comment Share on other sites More sharing options...
Kharl Posted March 9, 2017 Author Share Posted March 9, 2017 ok i will check thwe fuses, ground and both terminals of the fuse i will wait an hour since i have to pick up a frind at the train stop and i will save time and ccharge by turning the car on and doing the test when i go out to pick him up its a 10 minutes trip i hope not to broke something in the car and that the battery last for those 10 minutes Quote Link to comment Share on other sites More sharing options...
Kharl Posted March 13, 2017 Author Share Posted March 13, 2017 HI guys! thank you a lot for the time you spend helping me with thisi decide to do a rebuild, all electronic was bad, they put a new diode card and an used regulator, and gave me warranty, everything working fine by nowThank you! Quote Link to comment Share on other sites More sharing options...
