Battery and brake light came on!
Later tonight I'll be where I can try to find a fsm online.
The fuses look good... by testing with a voltmeter? You cannot tell by visual inspection. I have had failed fuses that look just perfect visually.
ok i will check thwe fuses, ground  and both terminals of the fuse
i will wait an hour since i have to pick up a frind at the train stop and i will save time and ccharge by turning the car on and doing the test when i go out to pick him up
its a 10 minutes trip i hope not to broke something in the car and that the battery last for those 10 minutes
HI guys! thank you a lot for the time you spend helping me with this
i decide to do a rebuild, all electronic was bad, they put a new diode card and an used regulator, and gave me warranty, everything working fine by now
Thank you!
