pitscars Posted March 10, 2017 Share Posted March 10, 2017 Hi guys - I am soon to change the timing belt on my 07 Impreza EJ204 with AVCS - apparently extra caution is needed - especially with the inlet cams ? is there a way to lock the camshaft pulleys in position ? any advice on the potential pitfalls would be greatly appreciated - Cheers Steve C Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 10, 2017 Share Posted March 10, 2017 No additional caution is needed and there is no need to lock the cams. It's just like any other DOHC Subaru timing belt job. When the marks are aligned the pistons are all halfway to TDC so the valves can't touch them. GD 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 10, 2017 Share Posted March 10, 2017 the left side intake cam (I think) will want to jump - but no damage happens if it does. There are devices and tricks to keep stuff aligned if you search. triple check alignment and do a tooth count after rotating the crank thru a few revs. before starting. Link to comment Share on other sites More sharing options...
pitscars Posted March 21, 2017 Author Share Posted March 21, 2017 Well - I managed to download the service manual - things I did not realize ---- the air conditioning belt is "stretch fit" - the valves can get tangled up if you turn the pulleys the wrong way - they say the cam pulleys and cover backing plate (LH) must be removed (along with the tensioner bracket) to remove the waterpump --- WTF ?? surely not ! Cheers Steve C Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 21, 2017 Share Posted March 21, 2017 (edited) dunno why it wouldn't be similar to this; Edited March 21, 2017 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 21, 2017 Share Posted March 21, 2017 You don't need to remove any of that just pull the water pump bolts. GD Link to comment Share on other sites More sharing options...
