Jman1991 Posted March 11, 2017 Share Posted March 11, 2017 I just pulled off my oil pan on my Loyale so that I can put a new gasket in. there is no way I am going to be able to put it back in without lifting the engine a bit! could someone please tell me where the mounts are located and how many bolts I will need to take out? Link to comment Share on other sites More sharing options...
Jman1991 Posted March 11, 2017 Author Share Posted March 11, 2017 sorry for the double post my computer keeps doing that Link to comment Share on other sites More sharing options...
turbosubarubrat Posted March 11, 2017 Share Posted March 11, 2017 (edited) One nut per side under the engine crossmember. Edited March 11, 2017 by turbosubarubrat Link to comment Share on other sites More sharing options...
Jman1991 Posted March 11, 2017 Author Share Posted March 11, 2017 thanks! Link to comment Share on other sites More sharing options...
turbosubarubrat Posted March 11, 2017 Share Posted March 11, 2017 You also need to at least unbolt the stabilizer bracket for the engine so you don't break it. You should have enough room to not need to undo the exhaust. Don't use a cork gasket just use a sensible amount of rtv. Link to comment Share on other sites More sharing options...
