Evil02outback Posted March 17, 2017 Share Posted March 17, 2017 Would anybody know where I can pick up a knock sensor connector on the harness side. Mine was pulled off right at the sealing rubber when I pulled the intake off I did not feel it when I pull it off making me think that it was not held on by much Link to comment Share on other sites More sharing options...
dp213 Posted March 17, 2017 Share Posted March 17, 2017 Best bet would be pick n pull or junk yard. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 17, 2017 Share Posted March 17, 2017 Just hard wire it. If you need to pull the manifold take out the 12mm bolt. If you need to replace the sensor - hard wire it again. They can be extremely troublesome so after many years of comebacks due to poor connections we just hard wire them if they give difficulty. GD Link to comment Share on other sites More sharing options...
Evil02outback Posted March 17, 2017 Author Share Posted March 17, 2017 Thanks GD that's what I did to get it running guess I'll just have to solder it Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 18, 2017 Share Posted March 18, 2017 Don't solder. Use seamless non-insulted splice connectors and a proper crimper and seal it with 3M heat shrink with sealant. There's a reason that NASA and the Nuclear industry both use mechanical connections for electrical. I use to solder but it takes a lot longer and there's concerns with lead free solder cracking with age, corrosion from the flux, etc. GD Link to comment Share on other sites More sharing options...
