Evil02outback Posted March 18, 2017 Share Posted March 18, 2017 I don't know much about which engines will work with what years but can I use a 05 shortblock in a 02 car and not have to change anything but the heads? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 19, 2017 Share Posted March 19, 2017 You shouldn't have to change the heads either as long as it's a non-AVLS motor. There are some weird California models from '05 that would not work. The pistons are different. If it has drive by wire that's an indication it will not work for your application. There are also some changes that were made to the PCV system around 01/02 IIRC but you can get around it. GD Quote Link to comment Share on other sites More sharing options...
