Retired mine up around 275,000 because at the same time it had a head gasket leak pressurizing the cooling system (would have lasted quite a bit longer I think), and a hatfull of things to fix for inspection, every rubber suspension bushing was shot, needed 4 struts and springs, and every steel brake line that wasn't already replaced due to rust was just waiting to rust thru. And it was really rusty.
  • 4 years later...
36 minutes ago, laegion said:
Just bought one with 196k, but suspected head gasket issue...I might be buying a JDM replacement engine.
That’s the way to go. New plugs and serpentine pulley bearings and 100k here you come.
Edited by idosubaru
  • Like 1
