06SubLegTx Posted March 21, 2017 Share Posted March 21, 2017 Hello, I'm most likely going to install Bilstein B6 Shocks & Struts on my Legacy. I know I need the B-Spec Front Strut Mount. I noticed on Tirerack that they say it may increase the ride height of the car, but they don't say how much. Has anyone ever installed these? Do you have an image with these on it? Any issues with Bilstein? The KYB that are on the back are very soft and bouncy.. Thoughts? Images? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 22, 2017 Share Posted March 22, 2017 (edited) I wouldn't even bother replacing the front strut mounts, their failure rate is miniscule and aftermarkets suck. Even the rears very rarely fail but if yours has been bouncing and weak they may have taken a beating - might want to replace the rear springs too as they've taken a larger brunt of the work load if you're noticing it bouncing excessively. How old are you existing struts and are they 2006 rear struts? For outbacks, it's common to use 00-04 struts on the 05-09 generation which is spec'ed a little light like you're describing, even the OEM struts i believe. I would at first be inclined to look into 00-04 KYB's. People also install baja turbo springs on their OBW's to stiffen them up a little - but people claim it raises the car 1/2" or so, although I didn't notice it, but might not be the best fit for a legacy? 00-04 KYB's and baja turbo springs are a great fit for OBW's and ride nicely. Edited March 22, 2017 by grossgary 1 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 22, 2017 Share Posted March 22, 2017 If you want amazing suspension, then get new KYB Excel-G's and a set of King springs. Primitive Racing here in the Oregon is the wholesaler for the US. They are so good people come back to my shop just to tell me how amazing they are. GD Quote Link to comment Share on other sites More sharing options...
