I'm thinking of lifting my 2008 Forester. if i go up 3 inches (strut spacers) will i need to also change out trailing arms and such?
I do realize i will need an alignment and adjustments.
any input would be great.
Thanks
The axles can't handle that much lift without the accompanying body lift as well. 2 inches is about the max.
Trailing arms would be fine inside of 2 inches depending on tire size. I don't think the spring perches allow for a big enough tire to rub though after 2 inches of lift.
