ThosL Posted March 28, 2017 Share Posted March 28, 2017 I ran a test at Auto Zone: It came back as ignition coil, based on: PO301 PO302 PO303 PO304 PO400 egr P1100 low input. I'm thinking wires as when it warms up it runs well. I don't think I've changed them since I bought it, a year ago. Quote Link to comment Share on other sites More sharing options...
lmdew Posted March 28, 2017 Share Posted March 28, 2017 NGK or Subaru Wires. NGK Plugs, Copper Core Subaru Coil if you need one. I have a bunch of Subaru Coils if you end up needing one. What year and what engine? Unlikely that they all failed at once, but start with a good visual inspection of the wires and go from there. Quote Link to comment Share on other sites More sharing options...
ThosL Posted March 28, 2017 Author Share Posted March 28, 2017 97 Outback 2.5. My guess is wires too. I ordered what I thought was an OE set on ebay for around $30 but had to cancel it when I realized it was only one. Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 28, 2017 Share Posted March 28, 2017 If the wires are old I'd replace them anyway. they are good preventative maintenance. All those codes at once would more likely be coil. I've got some coils laying around too. They aren't a real common fail point so a good used one is usually the way to go. let us know the year/engine or part number of your coil and one of us can probably set you up. Quote Link to comment Share on other sites More sharing options...
ThosL Posted March 28, 2017 Author Share Posted March 28, 2017 Is the diagnostic for coil failing hard start up, with check engine light flashing and then that going away when it heats up? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 29, 2017 Share Posted March 29, 2017 No. If it were a coil you would have misfire on 1/2 or 3/4. Misfire on all four cylinders is probably camshaft timing. May have jumped a tooth on the crank.... could be other problems maybe. It's not likely that both halves of the coil went out at the same time. Usually when they fail they just don't work at all on one half. Doubt that's your problem. GD 1 Quote Link to comment Share on other sites More sharing options...
ThosL Posted March 29, 2017 Author Share Posted March 29, 2017 It's the coil, I saw the sparks jumping out of it periodically. I'll check around on this as it is pretty bad. Quote Link to comment Share on other sites More sharing options...
ThosL Posted March 29, 2017 Author Share Posted March 29, 2017 Once I got the coil today, I pulled out the old one and then found it was not compatible. Good guy at Advance came out who is working on his mechanic certification and the wire was literally broken down corroded in the socket. So once I cleaned out the coil receptacle hole, I could put the old wire back in, no bad stuttering but the wire will need to be replaced. I heard Rock Auto is good, beats the $50 plus I see at Advance and Auto Zone. Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 29, 2017 Share Posted March 29, 2017 For Subaru get NGK wires. I've found ebay to be a bit cheaper than rockauto. 1 Quote Link to comment Share on other sites More sharing options...
