drewpear Posted April 4, 2017 Share Posted April 4, 2017 i'm working on this vehicle replacing some timing parts. the vehicle hasn't run for a year or so. of course i will be anxious to start it up after the timing work, but i'm feeling there may be some things i should do before i try to start it. oil and filter change comes to mind. what else should i be concerned with? thank you. Link to comment Share on other sites More sharing options...
DaveT Posted April 4, 2017 Share Posted April 4, 2017 Check the cooling system. Gas may be stale. If it's less than half, add a few gallons of new. Sitting outside or in a garage? 1 Link to comment Share on other sites More sharing options...
drewpear Posted April 4, 2017 Author Share Posted April 4, 2017 Check the cooling system. Gas may be stale. If it's less than half, add a few gallons of new. Sitting outside or in a garage? mostly outside Link to comment Share on other sites More sharing options...
idosubaru Posted April 5, 2017 Share Posted April 5, 2017 The biggest question is why did it sit for a year? A pristine driving Subaru with zero issues rarely sits in a pasture for a year. Subaru's routinely crank right up after sitting for long periods of time. I have no idea how many times I've done it, a year is chump change, I wouldn't even think about it. But yeah gas ages terribly so that's certainly a noteworthy point. Link to comment Share on other sites More sharing options...
lmdew Posted April 5, 2017 Share Posted April 5, 2017 Disconnect the coil Plug and crank it over until the oil light goes out to ensure you have it lubricated. Then plug the coil back in and start it. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 5, 2017 Share Posted April 5, 2017 first 2-3 stops should be in a 'controlled' area in case there's a lot of rust the pads need to get through. I guess monitor for any issues after you begin driving it (sticking calipers, rodent-chewed wires, etc.), perhaps accelerate some fluid changes. Tires over 6-7 years old or more might be starting to rot ? Link to comment Share on other sites More sharing options...
