1999 Legacy Outback Wagon Sitting For a Year
i'm working on  this vehicle replacing some timing parts.
the vehicle hasn't run for a year or so.
of course i will be anxious to start it up after the timing work, but
i'm feeling there may be some things i should do before i try to start it.
oil and filter change comes to mind.
what else should i be concerned with?
thank you.
The biggest question is why did it sit for a year?  A pristine driving Subaru with zero issues rarely sits in a pasture for a year.
Subaru's routinely crank right up after sitting for long periods of time.  I have no idea how many times I've done it, a year is chump change, I wouldn't even think about it.  But yeah gas ages terribly so that's certainly a noteworthy point.
first 2-3 stops should be in a 'controlled' area in case there's a lot of rust the pads need to get through. I guess monitor for any issues after you begin driving it (sticking calipers, rodent-chewed wires, etc.), perhaps accelerate some fluid changes. Tires over 6-7 years old or more might be starting to rot ?
