Scott in Bellingham Posted April 14, 2017 Share Posted April 14, 2017 I may pick up a XT6 for parts it has the front hubs, no rear hubs or brakes, what parts work to do a 5 lug setup, also what works from newer cars thanks guys on a 89 Loyale Quote Link to comment Share on other sites More sharing options...
Skylar Posted April 15, 2017 Share Posted April 15, 2017 Front hubs/ knuckles will work. Will have to drill out crossmember for the larger bolt on the xt6 control arm. Also swap top hats. Ea82 top hats on xt6 struts. Inner doj will have to be swapped if not a turbo loyale or turbo trans. Xt6 have 25 spline inner axle cups. NA ea82 has 23 spline. You can use EJ hubs/knuckles but will have to use ej axles. I think struts can be swapped around like using ej struts on xt6 knuckles or vice versa. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted April 15, 2017 Share Posted April 15, 2017 Only thing you really needed was the rear hubs. Everything else you need can be gotten off legacy or impreza for the front. Depending on what transmission you have would depend on what axles you need. 1 Quote Link to comment Share on other sites More sharing options...
