Axlespinner Posted April 15, 2017 Share Posted April 15, 2017 Hello everyone I'm wondering what is the biggest tire i can put on my 2001 outback limited i also plan on doing a lift among other things Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 15, 2017 Share Posted April 15, 2017 be sure to ask over at subaruoutback.org as well. I can't answer the question directly, but it would help folks if they knew your intended purpose/goal and how much lift. etc. Quote Link to comment Share on other sites More sharing options...
Axlespinner Posted April 15, 2017 Author Share Posted April 15, 2017 I want to lift it between 2" or 4 " but 4" lift will require more work this i know. But i want to turn my outback into my hunting rig Quote Link to comment Share on other sites More sharing options...
06SubLegTx Posted April 17, 2017 Share Posted April 17, 2017 Hello everyone I'm wondering what is the biggest tire i can put on my 2001 outback limited i also plan on doing a lift among other things https://www.wheel-size.com/calc/ Quote Link to comment Share on other sites More sharing options...
Axlespinner Posted April 17, 2017 Author Share Posted April 17, 2017 Thank you Quote Link to comment Share on other sites More sharing options...
Numbchux Posted April 17, 2017 Share Posted April 17, 2017 I run 215/65r16 on Forester 16x6.5 +48 wheels in the winter, which are a tad bigger than the stock 225/60r16s, on my stock '04 Outback VDC. Generally speaking, a 29" tall tire is about as big as you can get with stockish offset (obviously, lower offset helps with that, but creates other issues) before you start having trouble with strut clearance. With some trimming, 29" is doable on a 2" lift. Quote Link to comment Share on other sites More sharing options...
