6 lug conversion at stock height
Hey guys, I just started the process of redrilling my hubs to make them 6lug and I was wondering if I'll run into issues if I leave my car at stock height. Or if anyone has tire size suggestions for a 15x6 rim that might fit (Im not opposed to cutting out the fenders as much as needed seeing as their already rusted to he'll)
6-lug wheels come in a huge range of dimensions...
Keep in mind, Subaru wheels have a very high offset/backspacing. So real low-offset (like most chevy truck wheels) 6-lug wheels aren't going to fit well at all. But stock Toyota ones are close, and I think I've seen some Isuzu and Nissan offerings that are even higher-offset, which would fit well.
Tire size will make a big difference, too. ASSuming the car your referring to is the '85 4WD Wagon in your signature, you should have a fair amount of wheel well clearance.
  • Like 1
  • 1 month later...
Letter909, How did the  alloys from an Isuzu trooper work out for you?
I'm curious about inside fender rub, tire size you chose, and if you have a lift.
Would you do it again?  thanks in advance.
