moosens Posted April 20, 2017 Share Posted April 20, 2017 Car only has 97k on it but did sit in a garage much of its life and probably a long stretch before last fall going unused. Checked the fusible links and relays and fuses. My obvious engine harness grounds are all looking good and I will go over them again. Where should I look otherwise ? Have to double check but I'm pretty sure no switches are working at all. And yes I'm aware of the lock button. It's not just the master switch as I can see. Thanks for any help. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 20, 2017 Share Posted April 20, 2017 Under drivers seat carpet or under the door sill on the drivers side is where that stuff normally runs afoul. GD Link to comment Share on other sites More sharing options...
moosens Posted April 20, 2017 Author Share Posted April 20, 2017 Outstanding ! Thanks very much. I ended up cutting the corroded connectors off and spliced the wires. Then I taped it all tight , then duct taped it over all. The leaky sunroof has to be the culprit. Rear drivers side floor is soaked. Next up - seal up that pesky sunroof. Thanks again GD. Link to comment Share on other sites More sharing options...
