Do It Sidewayz Posted June 17, 2004 Share Posted June 17, 2004 When you buy a Reman Caliper from Napa, do you get the "caliper support". The piece which bolts to the spindle, holds the pads, and which holds the caliper "piston" section? I need the caliper bracket for my justy...and subaru wants 59 bucks. I can get a reman caliper for 72...so for the extra couple bucks i might as well Link to comment Share on other sites More sharing options...
nubs Posted June 17, 2004 Share Posted June 17, 2004 When you buy a Reman Caliper from Napa, do you get the "caliper support". The piece which bolts to the spindle, holds the pads, and which holds the caliper "piston" section? I need the caliper bracket for my justy...and subaru wants 59 bucks. I can get a reman caliper for 72...so for the extra couple bucks i might as well You will only get the caliper and maybe a few extra parts depending on the application.The bracket you are talking about would be a dealer item only. Try to look for one at a salvage yard. That would be your best bet. Link to comment Share on other sites More sharing options...
