06SubLegTx Posted May 6, 2017 Share Posted May 6, 2017 (edited) Hello, I'm going to use Fuji ThreeBond 1215 Gray Silicone Sealer: If you have ever used this sealer, I have a question. Oil Pan: 1. How wide of a "bead" to you run around the base of the Oil Pan? 2. Do/Did you run the bead "around" the mounting bolts, or just one side (inner or outer). 3. How did it hold up to leaks? Thanks Edited May 7, 2017 by 06SubLegTx Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 7, 2017 Share Posted May 7, 2017 Get 1217H from Nissan. Their price is about 1/3. Lay 1/8" bead on all raised surfaces. Inside, outside, and around the bolt holes. GD Link to comment Share on other sites More sharing options...
06SubLegTx Posted May 7, 2017 Author Share Posted May 7, 2017 Get 1217H from Nissan. Their price is about 1/3. Lay 1/8" bead on all raised surfaces. Inside, outside, and around the bolt holes. GD Thanks, I appreciate it.. Link to comment Share on other sites More sharing options...
