Violent crippling drivetrain bind in my RS
Hiya boys!
Bugeye RS 5 speed, 1" lift.
Broke at the end of a 14 hour drive. Car gets driven HARD.
Started popping, clunking, binding when we came off the highway.
Replaced suspect front CV.
Replaced suspect propshaft (it was toast!)
Most suspension components replaced in the last year
Idles fine, coasts with no bind
All gears engage
Rear diff spins free
Clutch has ~ 40k
I've had it to the mechanic for a second opinion, they pointed out the bad propshaft UJ.
Binds tight enough to stop the car at low speed. Binding much worse when turning.
I'm thinking further inspection of engine and tranny mounts? Or front, center diff?
FYI this is well beyond typical clapped-out Subie noises.
Edited by singletrack
See anything as in the engine shifting in the bay?
Will it do it in the air? If you can get it up on stands or a lift, try putting it in gear and cranking the steering to both locks, see if you see anything. That's where I would start.
Auto trans will shear the drum off inside the trans if driven with too much binding. Does anyone know the equivalent failure of an MT stressed internally with torque bind?
Torque bind seems the obvious starting point - maybe it's been happening awhile or was happening under the aggressive driving described which precipitated or accelerated the U joint failure and busted some stuff in the trans as well.
Never seen a ujoint mess up the trans wxcept shearing off and flailing around and crack the extension housing.
  • Like 1
