ThosL Posted May 24, 2017 Share Posted May 24, 2017 Do any of the exhaust system patches work? There are many products, I am surprised in this day and age there are not products that would seal leaks. Are there any epoxies, wraps or other products that help that? Quote Link to comment Share on other sites More sharing options...
DaveT Posted May 25, 2017 Share Posted May 25, 2017 Only temporary. If a part is rusted through, a lot of other places are likely soon to fail anyway. Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 25, 2017 Share Posted May 25, 2017 Good rust free Subaru system from CO. What do you need? Quote Link to comment Share on other sites More sharing options...
ThosL Posted May 25, 2017 Author Share Posted May 25, 2017 The pipe in back of the cat converters on my 97 Outback sprung a break; I picked up a couple high temperature fixes, will update on results. I'm sure industry has all types of fixes in addition to welding. Quote Link to comment Share on other sites More sharing options...
matt167 Posted May 25, 2017 Share Posted May 25, 2017 There is a foil tape that works. Hard to find, but that's about it.. regular " Muffler tape " and " muffler putty " don't work 1 Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 25, 2017 Share Posted May 25, 2017 I have used, to good effect: Aluminum duct tape backed by hose clamps (just make sure the clamp forms a 'heat sink' over the hole) small holes plugged with the white hardening sealant 1/2 sections of pipe (or bent sheet metal) over a blob of the sealant, held in place by hose clamps The small holes I've dealt with have usually been from a welded-on hanger ripping out. Good pipe around a rusty strip or hole the size of a dime or so. 1 Quote Link to comment Share on other sites More sharing options...
ThosL Posted May 25, 2017 Author Share Posted May 25, 2017 I may try that but the pipe is tapered into the joint so unless the aluminum tape is formable, it may not be possible to get the effect with the hose clamps. Quote Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 25, 2017 Share Posted May 25, 2017 hose clamps and a piece of sheet metal work best as a patch lasts a while too but will eventually fail many months down the road Quote Link to comment Share on other sites More sharing options...
jp98 Posted May 26, 2017 Share Posted May 26, 2017 If it is just a hole in the piping then you can try a band clamp that you can get from NAPA or other auto parts stores. Quote Link to comment Share on other sites More sharing options...
brus brother Posted May 26, 2017 Share Posted May 26, 2017 I once used high temp furnace caulk in a tube. Odd location and not accessible as the defect was set back below a reinforcing plate where two pipes join so being able to squirt this stuff in was a real plus. It's been in there at least 2 years and is still holding. If you can lather some of this stuff on and reinforce it with some sheet metal and a clamp, you should get some mileage out of it. Quote Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 26, 2017 Share Posted May 26, 2017 FURNACE CAULK you say?!? I never knew such existed! Yet there it is right at Home Depot even. You sir, are a genius!! I'm gonna try that, thanks! Quote Link to comment Share on other sites More sharing options...
brus brother Posted May 26, 2017 Share Posted May 26, 2017 (edited) Actually lists automotive as one of its uses on the tube and says it's rated to 600 degrees. Edited May 26, 2017 by brus brother Quote Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 26, 2017 Share Posted May 26, 2017 i have used rtv copper on exhaust flanges with great results Quote Link to comment Share on other sites More sharing options...
ThosL Posted May 27, 2017 Author Share Posted May 27, 2017 I got some of the 3M aluminum tape with the high temperature metal cement and two hose clamps, hopefully it will hold. Quote Link to comment Share on other sites More sharing options...
bstone Posted May 29, 2017 Share Posted May 29, 2017 https://smile.amazon.com/FiberFix-857101004235-Heat-Wrap/dp/B00N582CBY Quote Link to comment Share on other sites More sharing options...
06SubLegTx Posted May 31, 2017 Share Posted May 31, 2017 Good rust free Subaru system from CO. What do you need? Can I ask what company you are referring to? My 06 Legacy was a northern car.... my exhaust pipes are very rusty... Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 31, 2017 Share Posted May 31, 2017 I think he means colorado Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 1, 2017 Share Posted June 1, 2017 Can I ask what company you are referring to? My 06 Legacy was a northern car.... my exhaust pipes are very rusty...No company exactly, you have to do some legwork. Post on forums, in the parts areas, that you're looking and call places on www.car-part.com. Even if places don't list exhaust (some places may not list it) all you need to do is find some places offering parts from one of those vehicles and ask if they have the exhaust. For instance Look up an engine for your then call those places for exhaust. Two of my current Subarus have Colorado and California exhausts on them. Quote Link to comment Share on other sites More sharing options...
brus brother Posted June 1, 2017 Share Posted June 1, 2017 (edited) No company exactly, you have to do some legwork. Post on forums, in the parts areas, that you're looking and call places on www.car-part.com. Even if places don't list exhaust (some places may not list it) all you need to do is find some places offering parts from one of those vehicles and ask if they have the exhaust. For instance Look up an engine for your then call those places for exhaust. Two of my current Subarus have Colorado and California exhausts on them. Good to know. I didn't think it was legal to resell cat converters?? maybe due to high incidence of theft for quick cash as I recall. Friggin' opiod epidemic. Edited June 1, 2017 by brus brother Quote Link to comment Share on other sites More sharing options...
