Leone wagon ea82 head problem
The head gasket fire ring is clearly blown. You need to check head flatness and proper bolt torque.
The gasket and head coolant passage mismatch is normal. That is not a sign of failure or a cause. The previous picture shows clear carbon tracking from fire ring to coolant port.
Edited by GeneralDisorder
  • Like 2
There is some seriese issues if that head gasket was done 2 months ago it looks like its never been done before and if in fact it was they did a horable job every thing should be clean and carbon free when put back together there shouldent be any rust anywere unless water sat in the cylinder for a long time even after a year of sitting outside 100ft from the ocean with no plugs and water in the cyliders i havent seen anything that ugly that looks like it sat exsposed to the air and water for years like a junk yard head nothing some time with a wire wheel and a good cleaning wont fix and make sure to use atleast some coolant in the system it helps to keep the corosion in the system down so if someone did do the gaskets they dident prep the head and that would be why it failed but i dont know why anyone would go to the trouble of changing a head gasket and not cleaning the surfaces  on the head and block
On second thought i did have 1 head that looked like that it had water in the cylinder for about 10 years it cleaned up i have it somewere the rings and pistons cleaned up to but the cylinder boar was pitted and has a valley kinda thing going from the rust lol im sure it could be honed out but why ive got 3 more blocks laying around
The crack is so common that there was a tsb from Subaru about it years ago.
Headgaskets are oem or Fel Pro only. Intake gaskets are oem only.
Also, the 2 o rings on the oil channels, oem.
  • Like 1
1. the heads need resurfaced for flatness and finish. can do it yourself with vintage Italian marble like this:
http://www.ultimatesubaru.org/forum/topic/122588-diy-head-resurfacing-or-post-apocalyptic-machine-shop-techniques/
2. Subaru or Fel Pro head gaskets only
3. Subaru intake manifold gaskets - others are thin flimsy cardboard
4. The cracks are normal, every EA/ER head I've ever seen except maybe one or so has them. If they're too deep they can breech coolant/exhaust passages. This happens more often on turbo engines than non-turbo. Heads can be pressure tested, not sure how to test them at home but you can look into the exhaust ports for signs of cracking there.
Edited by grossgary
