Leone wagon ea82 head problem
I Would say that intake valve is toast with all the pitting its gona colect carbon and ruin the air flow around the valves at best ive had to many valves in that codition snap on me and take out a piston or a whole motor if it just looks worse than it realy is then clean the isht out of it till it shines then the carbon will have a hard time sticking to it
  • Like 1
Step 1 22ft lbs
Step 2 43ft lbs
Step 3 47ft lbs
Be sure to clean the holes and the bolts. Oil the threads.
The sequence must be followed also, as shown in the shop manual. There should be links somewhere.
