dp213 Posted May 30, 2017 Share Posted May 30, 2017 On my 99 outback the key sometimes won't come out of the ignition. I had a new key made by the dealer with the vin and it still did it. I then replaced the ignition itself (as in the key and tumbler part.) It still does it sometimes. I am stumped, any thoughts? Thanks Dp Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 30, 2017 Share Posted May 30, 2017 do you park with the wheels turned at an angle, and possibly on a slope? all cars can sometimes need some 'counter pressure' applied to the steering wheel to take some friction off the locking mechanism. Link to comment Share on other sites More sharing options...
dp213 Posted May 30, 2017 Author Share Posted May 30, 2017 Parked on flat ground, same spot every day. No pressure on anything. Link to comment Share on other sites More sharing options...
dp213 Posted May 30, 2017 Author Share Posted May 30, 2017 Shake and turn the steering wheel and shifter, doesn't help. Link to comment Share on other sites More sharing options...
forester2002s Posted May 30, 2017 Share Posted May 30, 2017 WD-40? Link to comment Share on other sites More sharing options...
golucky66 Posted May 30, 2017 Share Posted May 30, 2017 (edited) Park/neutral switch could case intermittent issues like that. Assuming its an auto. Edited May 30, 2017 by golucky66 Link to comment Share on other sites More sharing options...
dp213 Posted May 30, 2017 Author Share Posted May 30, 2017 Deep creep instead. I like it better Link to comment Share on other sites More sharing options...
djmark7 Posted May 30, 2017 Share Posted May 30, 2017 does the key turn all the way back to the 'off' position? Link to comment Share on other sites More sharing options...
Gloyale Posted May 30, 2017 Share Posted May 30, 2017 Could be the interlock with the auto trans. Not recognizing that car is in "P" or not disengaging if it is recognizing. You can pull covers off the column and remove the little interlock solenoid. 2 screws......never have to worry about it again. 1 Link to comment Share on other sites More sharing options...
dp213 Posted May 30, 2017 Author Share Posted May 30, 2017 The key does turn all the way back to the off position. I will tryt to figure out the interlock solenoid. Thanks Link to comment Share on other sites More sharing options...
dp213 Posted July 14, 2017 Author Share Posted July 14, 2017 Google, how do you get the bottom screw out? So I need to remove the steering wheel and everything. Thanks Dp Link to comment Share on other sites More sharing options...
