pitscars Posted June 6, 2017 Share Posted June 6, 2017 Hi all - My 82 sportswagon has been refusing to start in the morning - it has been cold and dewy just lately and the old girl doesn't like it - this morning I had to have the bonnet up while the sun dried things out for 10 minutes - started fine after that - never had this problem with any of my other Subarus - Brumbys - L series or wagons - so I bought a hair drier today at the second hand shop - a quick burst of warm air over the coil and distributor cap used to wake up my old Mitsubishi Sigma years ago - so tomorrow I will give it a try - but it does not explain why THIS car has the damp don't want to. Link to comment Share on other sites More sharing options...
Subaru Scott Posted June 6, 2017 Share Posted June 6, 2017 You need to take the distributor cap off and scrub it clean. Of course, if it looks really worn, just replace it. Clean the top of the coil as well. Link to comment Share on other sites More sharing options...
Dee2 Posted June 6, 2017 Share Posted June 6, 2017 (edited) On 6/6/2017 at 12:12 PM, Subaru Scott said: You need to take the distributor cap off and scrub it clean. Of course, if it looks really worn, just replace it. Clean the top of the coil as well. +1 You may have a hairline crack in the cap, so you should check for that too. Edited June 6, 2017 by Dee2 Link to comment Share on other sites More sharing options...
Rust Posted June 9, 2017 Share Posted June 9, 2017 If you are cash poor and can't swing a new set of wires and cap, just clean and dry out everything. Then smear some dialectic grease, vasoline, or whatever you have on hand around the wire connections, to keep the moisture out. This will buy you some time until you buy the parts you need. Link to comment Share on other sites More sharing options...
