 does anyone in connecticut have one of the long bolts and nut that aren't destroyed? im speaking of the long like 12 inch bolt that goes through the 2 lower control arms on the rear. it is for a 2002 forester but im pretty sure the same bolt for other models will work. im so close to getting the car back on the road but am being held back by one dam bolt.
he bought one from the dealer. reason for replacement was he drove it without a wheel bearing for god knows how long. replaced the shock hub bearing axle caliper caliper bracket abs sensor and tone ring parking brake hardware still need a new parking brake cable he may not buy it. thankfully we used a junk yard part so most of this stuff was already assembled.
yes the rotor did saw through the caliper. its amazing the wheel was still on the car. i got the rear together today and took it for a test drive no sounds from the rear anymore but he had 2 wheel bearings that were bad the front passenger one is also loose and just starting to rub the rotor into the caliper bracket when turning so yea still got more work ahead of me.
