Out of town and burning up - help me get my windows down?
Yes. Pull the door panel, look for the power window motor, the connector attached to it will only have two pins. One polarity sends it up, the other way around will bring it down. Only if the motor itself isn't toast though.
Thanks, maybe I won't dehydrate!
Great - right the motor is way simpler than the switch, perfect!
Two pins - do I ground the pin or give the pin 12 volts?
I may have a multimeter with me, if so ill check first.
Copy - I'm almost positive the motor is good. Both sides are inoperative and some minor electrical weirdness.
I just fixed this on my car and it wasn't the window motor it was the switch.
If you have a power probe it gets real easy: ground one side power the other, or reverse. (I understand you're traveling and don't have access to tools.)
Not sure where to are trying to get into the wiring... Going by my experience with 4wd wagons, if none work, the main power feed is broken. Maybe fuse blew or broke..
I had to take the door panel off to bypass the broken power feed wire in the drivers door. The motors have 2 pin connectors. 12v and gnd will decide which way it runs up or down, but again, door interior has to come off. I'm pretty sure that an xt would be similar.
if the drivers side switch doesn't work, does it take out the passengers side switch as well? I would think the passengers side still works? None of mine work so I assumed it was something other than the motors or switches.
Thanks. Cursory check shows fuse and fusible links good. I'll check switch first and give it 12 volts or ground to get home if I can find those wires/pins.
Yes XT trims come off really easy, done it 50 times, everything is right behind there. I have basic tools and wire so I can rig something temporary.
Yeah, it's gotta be a main power or ground issue if nothing works from either side.
I have a mini led test light, I think I got with a trailer plug adapter kit, that I keep in the glovebox for just such an emergency.  ;)
Being led though, you have to keep the polarity right!
Edited by Subaru Scott
