golucky66 Posted June 15, 2017 Share Posted June 15, 2017 Does anyone know or have experience with the max tire size that can be put on a 04 Baja with a 2" lift (strut spacers) Factory size is 225/60/16 which if my calculations are right is about 26.5" in diameter. What could i realistically fit under there with minimal rubbing. I saw somebody posting about barely being able to fit 29" tires with a 4" SJR lift (subframe drop etc.) and it seems like I'm missing something. Raising the vehicles body 4 inches and barely getting 3" extra diameter in for tires? Am i missing something? Does anyone on these forums have any experience with lifting Baja's? Link to comment Share on other sites More sharing options...
Gloyale Posted June 15, 2017 Share Posted June 15, 2017 Does anyone know or have experience with the max tire size that can be put on a 04 Baja with a 2" lift (strut spacers) Factory size is 225/60/16 which if my calculations are right is about 26.5" in diameter. What could i realistically fit under there with minimal rubbing. I saw somebody posting about barely being able to fit 29" tires with a 4" SJR lift (subframe drop etc.) and it seems like I'm missing something. Raising the vehicles body 4 inches and barely getting 3" extra diameter in for tires? Am i missing something? Does anyone on these forums have any experience with lifting Baja's? Unless you lift the car so high the wheels are no longer in the wells, you will always be limited by the diameter of the wheel well opening. Moslty at the lower corners. The opening is only so big across. Link to comment Share on other sites More sharing options...
golucky66 Posted June 15, 2017 Author Share Posted June 15, 2017 Gotcha. So how do some of you guys get away with running massive tires on like the EA's? Modified fenders or are they just big to begin with? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 16, 2017 Share Posted June 16, 2017 Gotcha. So how do some of you guys get away with running massive tires on like the EA's? Modified fenders or are they just big to begin with? EA struts have more clearence, i think your struts are good upto 29" tall tires Link to comment Share on other sites More sharing options...
golucky66 Posted June 16, 2017 Author Share Posted June 16, 2017 Ok. Cool. Thanks for all the info! Link to comment Share on other sites More sharing options...
