Checkerboard Comet Posted June 22, 2017 Share Posted June 22, 2017 Hey guys, I'm going to attempt to install the 1993 Loyale dashboard into a 1985 GL.........and I've never took one out before. Anybody out got any tips or tricks to make it easier? Perhaps a diagram of the screw locations would be of great help. Also, is there anything I need to be cautious of? Thanks, I appreciate the help. Gary Link to comment Share on other sites More sharing options...
john in KY Posted June 22, 2017 Share Posted June 22, 2017 Pull the steering wheel column. Remove that plastic strip at the base of the windshield to exposes a few mounting screws. Take it from there. Probably will take 2 hours. Link to comment Share on other sites More sharing options...
DaveT Posted June 23, 2017 Share Posted June 23, 2017 I've pulled them. A lot of things, just take time. A FSM has helpful information. Make notes / pictures if you think you might have trouble remembering how things were.Remove the glove box, and the kick panels and instrument cluster first. You *might* be able to get it out by just dropping the steering column from it's mounts, but I don't recall. Link to comment Share on other sites More sharing options...
rae houghton Posted March 3, 2019 Share Posted March 3, 2019 Gauge cluster ....This is the same as the instrument cluster I presume? The temperature gauge in a car I looked at is not working. It was suggested that the gauge cluster needed to be changed. But perhaps some other reasons. ' My mechanic , who I use when I can't figure out things myself (and with help from all the minds on this site) says they are a pain in the rump roast. He doesn't like to work on them. Probably doesn't want customers to be angry when they see his bill for such a job. Any suggestions to make life easier? Some other tests before going to such trouble? This car I was looking at with a partner needed a Roadworthy to get on the road. Probably no one would notice that the temp. gauge wasn't working. But , for one's own peace of mind, you need to know if the car was overheating.? Rae Link to comment Share on other sites More sharing options...
BEECHBM69 Posted March 3, 2019 Share Posted March 3, 2019 IMO, it would be much easier and cheaper (if you aren't doing it) to install an aftermarket temp gauge and leave the dash alone. Dan Link to comment Share on other sites More sharing options...
DaveT Posted March 3, 2019 Share Posted March 3, 2019 The gauge or instrument cluster is a small thing compared to replacing the entire dashboard, which is what the OP was about. It's a little fiddly, but not that big of a deal. If the temperature of the engine goes over normal while low on coolant, it is a pretty high risk of causing head gasket failure. It is also too late if you use this to check the coolant level. But it can save you having to do crank bearings and rings and worse. Link to comment Share on other sites More sharing options...
FerGloyale Posted March 3, 2019 Share Posted March 3, 2019 93 loyale dash won't work in an 85. Wiring changes. very small, but they are there. you need and 85 or 86 only. Link to comment Share on other sites More sharing options...
carfreak85 Posted March 4, 2019 Share Posted March 4, 2019 20 hours ago, FerGloyale said: 93 loyale dash won't work in an 85. Wiring changes. very small, but they are there. you need and 85 or 86 only. Are you saying the later dashboard wont physically fit the '85, or that OP needs to swap over all the electronics to maintain functions? Link to comment Share on other sites More sharing options...
FerGloyale Posted March 5, 2019 Share Posted March 5, 2019 On 3/4/2019 at 8:09 AM, carfreak85 said: Are you saying the later dashboard wont physically fit the '85, or that OP needs to swap over all the electronics to maintain functions? It physically fits. However, I believe the pinouts of hte dash connectors changed just a bit. Can't remember what but it's couple wires. It could certainly be worked out with some splicing/repining. I'd need to compare FSMs to tell ya for sure. Does the 93 loyale Dash even have a Oil pressure or Volt gauge? Link to comment Share on other sites More sharing options...
carfreak85 Posted March 5, 2019 Share Posted March 5, 2019 Ok, that's what I was getting at, you're talking about the electrical connections in the gauge cluster, I'm only talking about the dashboard itself, not any of the electronic bits. Link to comment Share on other sites More sharing options...
DaveT Posted March 5, 2019 Share Posted March 5, 2019 My 93 loyale came with that stripped down version instrument cluster. Oil light, not gauge. No volts? I have fsm from 86 and 90, compared everything. Swapped a few bits around, changed out the switch for the sender, and I now have a full GL instrument cluster in my 93. The oil switch vs sensor used the same wire, same location. The volt meter just taps existing wiring. 1 Link to comment Share on other sites More sharing options...
