Subaru Scott Posted June 28, 2017 Share Posted June 28, 2017 Black and white is relative, my friend... Quote Link to comment Share on other sites More sharing options...
Chuck_S Posted August 4, 2017 Author Share Posted August 4, 2017 So I finally got the XT into a Subaru Performance shop, and they said two things were causing the car to bog down and quit. -The fuel pump was only putting out 4, and should be putting out 10 so they put in a new pump...... however car still did the same thing.... -They said I need a new MAF sensor for $350 + $100 installation Apparently the MAF sensor gets hot, overheats, and that is causing the car to bog down and quit. (Putting it in neutral, turning the key on/off resets it apparently, and I'm good for another 5-10 minutes.....) Well got the fuel pump changed out, diagnosing fees, and an oil change that only costed me $544...dang... So we'll see in a while if the MAF sensor is the cause of the problem,..... soon as I get another $450 together..... Thanks to everyone for their help! Chuck. Quote Link to comment Share on other sites More sharing options...
colemanapp Posted August 4, 2017 Share Posted August 4, 2017 it'd sure be worth checking that fuel sock in the gas tank. I don't know if that model has an accessible fuel level sender mounted on the rear of the tank but if you could remove that and look inside the tank, you'd probably find it full of crud and that sock caked in white gunk. Sounds exactly the same problem as a couple of older subarus we rescued. Dirty fuel tank, clogged pickup in tank. Quote Link to comment Share on other sites More sharing options...
Chuck_S Posted August 4, 2017 Author Share Posted August 4, 2017 @colemanapp Hey thanks for that great info, I'll ask them if they had a chance to check that. If not, I'll have 'em check it on the next go around. Thank you! Chuck. Quote Link to comment Share on other sites More sharing options...
colemanapp Posted August 4, 2017 Share Posted August 4, 2017 to clean the tank, we went old school and dumped some clean gravel in it and shook it around. I couldn;t believe how much stuff came out. Coated the tank and its been good since. Quote Link to comment Share on other sites More sharing options...
Chuck_S Posted August 4, 2017 Author Share Posted August 4, 2017 @colemanapp Wow, that's great advice. I just talked to the shop, and they said mine doesn't have the fuel sock. They said they checked the flow and it was good, but I'm guessing there still could be gunk in the bottom of the tank... Quote Link to comment Share on other sites More sharing options...
