wirelessenabled Posted June 27, 2017 Share Posted June 27, 2017 I am doing the 105,000 mile timing belt service on my son' s 2010 Outback. My question is about the water pump. The FSM says to remove the drivers side cam pulley and the back side of the that timing cover to remove the water pump. The setup looks exactly the same as the water pumps I have replaced on a couple of 2000 OBW with 2.5 SOHC. I just went ahead and unbolted the water pump and it came right out. I reinstalled a new Aisin one using the included metal gasket. Went back together fine with no problems or any weird glitches. Is there something I am missing by not following the FSM on this replacement? Thanks in advance. Link to comment Share on other sites More sharing options...
wirelessenabled Posted June 27, 2017 Author Share Posted June 27, 2017 Anybody? Covers are going on in a couple of hours. Link to comment Share on other sites More sharing options...
golucky66 Posted June 27, 2017 Share Posted June 27, 2017 (edited) Well, considering you had no issues installing the new one. I wouldn't worry about what the manual says. I've had a few times were the service procedure was overcomplicated for the task at hand. Edited June 27, 2017 by golucky66 Link to comment Share on other sites More sharing options...
idosubaru Posted June 28, 2017 Share Posted June 28, 2017 FSM routinely mentions unnecessary steps. Assemble and don't worry about it. Link to comment Share on other sites More sharing options...
Silent Bob Posted June 28, 2017 Share Posted June 28, 2017 Slightly easier to get the pump in place, but not necessary. and not worth the trouble unless replacing cam seals also. 2 Link to comment Share on other sites More sharing options...
wirelessenabled Posted June 28, 2017 Author Share Posted June 28, 2017 Thanks! I got hung up at work last night and didn't get home until too late so covers going on tonight! Link to comment Share on other sites More sharing options...
wirelessenabled Posted June 30, 2017 Author Share Posted June 30, 2017 Finished putting the car back together. 10 mile test drive revealed no problems. 2 Link to comment Share on other sites More sharing options...
