06SubLegTx Posted June 29, 2017 Share Posted June 29, 2017 Hello,I have a 06 Legacy with a engine splash shield that is only a couple of months old and it is already starting to sag on the Driver Side where there is less plastic material.Has anyone ever found a way to brace it up or modify it so that it's not sagging like it's many years old when it is only 6 to 9 months?Thanks for and constructive input. Link to comment Share on other sites More sharing options...
hzimmerman1111 Posted June 29, 2017 Share Posted June 29, 2017 It must be missing some of its hardware. Kind of a general description, but sometimes the side screws are forgotten -- the ones you get to inside the front wheel wells. This site can probably assist better with more specific information. Link to comment Share on other sites More sharing options...
06SubLegTx Posted June 29, 2017 Author Share Posted June 29, 2017 It must be missing some of its hardware. Kind of a general description, but sometimes the side screws are forgotten -- the ones you get to inside the front wheel wells. This site can probably assist better with more specific information. Hey, I put all new hardware along with the new guard. Where it is starting to slowly sag is the driver side where there is less plastic. I was hoping someone in aftermarket make one for the 4th gen Legacy. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 29, 2017 Share Posted June 29, 2017 Those are garbage. Get a proper skidplate from Primitive Racing. GD 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 29, 2017 Share Posted June 29, 2017 if all the bolts and clips are in place - don't worry about it, UNLESS you plan to actually be offroad a lot, then, GD's suggestion is the way to go. Link to comment Share on other sites More sharing options...
golucky66 Posted June 29, 2017 Share Posted June 29, 2017 (edited) All the plastic splash shield underneath is really for is aerodynamics. To help prevent wind from getting stuck under the engine when driving. Helps with fuel economy a little. That's why most if not all newer cars have then. Don't think that dinky plastic is going to protect you from anything. Lol. Edited June 29, 2017 by golucky66 Link to comment Share on other sites More sharing options...
Mike104 Posted June 30, 2017 Share Posted June 30, 2017 I took mine off when I got my 03 Forester. Most of the hardware was missing and it weight another 5 pounds from all the oil soaked into the matting. Link to comment Share on other sites More sharing options...
Gloyale Posted June 30, 2017 Share Posted June 30, 2017 All the plastic splash shield underneath is really for is aerodynamics. To help prevent wind from getting stuck under the engine when driving. Helps with fuel economy a little. that and to keep oil from dripping on the ground until after the warranty is up. Link to comment Share on other sites More sharing options...
