EA to EJ woes
Hello everybody I'm a newb at harnesses, so please bear with me. It's a 98 outback sport ej2.2 going into a 91 loyale. Harness trimmed already by ADF. Both power wires coming from the EJ fuel pump relay (FPR) are showing 12V constant, and i do not hear the FPR click when ign is on. Obviously thats not good, should any of the wires coming from the FPR be grounded? Another issue is when I have the fuel pump connected to constant 12V it won't start. It starts with starter fluid no problem. Injectors are getting 12v, but the ECU is not sending the ground signal! All of my grounds are good, I can not figure it out!!
TL;DR Fuel pump relay power wires constant 12V. Injectors not firing, not receiving ground signal from ECU. please help my head hurts
Be as blunt as you want, anything helps
You're using an OBD2 set up? :unsure:  If it came from a car with an auto and ABS, you're going to run into issues with the SES being on all the time. As far as your relay, should be 4 pins. Pin 87 should go out to the fuel pump. Pin 30 should have 12v constant. These two pins are interchangeable depending on how the vehicle was wired. Pin 85 should have 12v constant and pin 86 should be the ground signal from the ECU to turn the relay on. These two pins are also interchangeable. If the relay is not turning on and you have no injector pulse from the ECU, you have either a power or ground issue to the ECU, bad ECU or, it's not receiving the theft deterrent signal it's expecting (if it had VTD) or some other sensor info from another module that's no longer there. You should have used and OBD1 engine and harness. Methinks you're in for some headaches.
Yes OBDII and came from a car with manual ABS. Haven't thought about anti theft, as the harness did come with a high end alarm... It is pretty much a headache I've literally triple checked all of my wiring, grounds, and everything seems to be where it should be
FPR has two 12v leads. An ECU coil ground control, and a 12v output to the fuel pump. The relay should fire when you turn on the ignition (switched power to ECU goes live) and then shut off and wait for cam and crank sync.
If you are not getting the fuel pump prime pulse then the ECU is not fully powered, the relay is bad, the ECU is bad, or the wiring is wrong.
  • Like 1
There is no issue with using an OBD II harness.  Certainly not an 98 anyhow.
Stripped properly there is ZERO interaction between the ECU and old ABS system.  Not his problem.  Even from an Automatic, an OBD II harness will still run fine.
To the OP.  So you've got 12v on 2 of the 4 Fuel Pump relay wires?  That's a good start.
There should be a 3rd wire, thick gauge, probably Black/red but maybe different.  Anyhow it's the one that would run to the Fuel Pump for it's power.
The 4th wire is the key.  It's skinny, and likely a light green and connects back to the ECU.  This is the Wire that the ECU grounds to turn on the relay to the pump.  You can test by Disconnecting the plug from the ECU, and give the relay ground to that pin.  It should then run the pump.
Given that you don't have Injector pulse I am gonna guess you don't have 12v to the ECU for "run" position.  do you have a Wiring schematic for that harness?  Pinout of the ECU?
Edited by Gloyale
  • Like 1
Thanks for the replies everyone. Here is the pinout for my ECU
My harness was stripped by a reputable person, but I do not know how well the job was done (said a couple wires he didn't know what to do). Right now the wires going to pin 81 (at/mt identification), 17,18 (control systems) are not connected to anything. Should those be grounded? I know the relay itself is good for the fuel pump, i have 3 different ones that I tried.
I'm going to try my ecu in another car tomorrow to see if my ecu is good.
Yeah, the wires from 17 and 18 need to be tied into ground.  that is likely the issue.
Make sure pin 85 is connected to Ig. switched power.
Ground pin 81 IF you have a Neutral switch in your trans.  Otherwise I'd recommend leaving it in AT designation (open) It will idle better.
Fuel pressure and solenoids and level sensors you can leave out.  Will throw codes but not needed to run just great.  Can get rid of a few of the codes with a couple resistors to ground. But I kept always getting a "MNFC. Controlled Equip"  code using a 96 OBD II Outback 2.2 computer.  Same pinouts I believe.
Also disregard the pins mentioned here by SkiShop.  He's talking about Bosch type relay configuration with standard 30/85/86/87/87A type designation.  Not applicable to the hitachi/matsuba relays on a subaru.
GLoyale and GD you guys are a huge help!! I hooked pin 85 to ign on and 17,18 to ground and it started right up!!!!! Thank you guys so much for your help!
To do:
1. Figure out the fat vacuum leaks
2. Still have to figure out the FPR (only have it connected to constant 12V)
3. Figure why when key is out on off ign is still on
Edited by alexbuoy
  On 7/9/2017 at 11:51 PM, alexbuoy said:
i got a guy for smog lol
Some of us aren't so lucky. Last time I went for smog the SOB broke the radiator cooling fan switch causing it to overheat on the rack.
WTF he was doing with his hands in there I'll never know. :angry:  Real nice!
  • 2 weeks later...
holy crap!
Engine Change Guidelines
Engine changes continue to present problems and challenges to car owners and technicians. Our recommendation is to rebuild and reinstall the original engine, transmission, and emission control configuration
To fix move out of California. vote with your feet.
  • 1 month later...
  • 5 years later...
Expand
Does anyone have a diagram of the ECU pins? I’m chasing the same problem in my swap. I have a 83 GL I’m putting an OBD1 EJ222 out of a 92 legacy in. Not getting any pulse from the ECM to the injectors I’ve gone over the wiring over and over. Got the harness trimmed by SJR but he left a lot of stuff not labeled so I’m not sure what everything is…. Engine was in a AT but I got the right ignition coil for a MT… might be worth mentioning I wired my fuel pump to a switch for more anti theft, hoping there’s no way that could be the cause for my headache… getting to the point where I want to push the car off a cliff and cut my loses. Any help is alpreciated
I have a pin diagram but they don’t number up to 85 or anything it just goes through like 1-26 depending on the size of the pigtail? Am I just stupid? Can someone PLEASE shed some light on this. I feel like a idiot and am so beyond frustrated with this whole thing I DONT KNOW ANYMORE
Edited by 83subaruGLchick
Expand
Just start a new thread, instead of digging up a 5+ year old one. And list your exact symptoms and what you've tried.
Lots of good FSMs on www.jdmfsm.info
