If it's the plastic wood grained trim it generally comes off by prying with a flat putty knife/plastic pry tool.  The key is to know where to use the tool.  I don't have a 2011 so I really can't tell you where.
Look at the replacement part as your guide - it'll be abundantly clear how it comes off:
remove fasteners
pry at the locking tabs
if it's tight - work your way around the entire circumference giving it some movement and loosening it up before trying to pop it all the way out.
  • Like 1
