what kind of muffler on 2gen brat?
Need to get the exhaust reworked. Gonna have them cut out the catalytic converter and run a 2 inch pipe. I'm hoping they can reuse the original Y pipe. What kind of muffler would be good. Don't necessarily want anything really loud, but a little would be ok. I'm guessing the stock mufflers were pretty quiet.
Most standard mufflers are going to be louder than factory. I had a hard time finding one as quiet as stock without running a resonator too. "Turbo" style mufflers, originally developed by GM for the Corvair turbo, by the way, will give a little rumble.
Edited by Subaru Scott
I've got Magnaflow stainless mufflers with two inch stainless pipe on all three of mine. A little rumble without being obnoxious at speed.
Stainless is a little more expensive, but if you're planning on keeping the car, you'll never have to replace it.
Dan
Edited by BEECHBM69
  • Like 2
You'll wanna keep it high & tight to underside. This round Magnaflow fits very nice..............post-30768-0-07856800-1499958859_thumb.jpg
Don't remember what model muffler but good tone & not very loud.
Edit - page 54 of Magnaflow catalog, model 12634 SS 6 inch round by 14 inch case. 2 inch in & out offset
Edited by czny
I'm shocked nobody else has said this yet, but:
Don't be a jerk and remove your catalytic converter.
If all you want is a louder than stock exhaust to do it properly by getting a new, high-flow cat and leave the exhaust without a muffler.  You will gain very little power by keeping any portion of the OEM exhaust anyway.
Again, don't be "that guy".
Well, if the $10,000 fine from the EPA for tampering with an emissions control device doesn't do it for you, maybe the fact that without a cat you are basically poisoning yourself and everyone else around you will change your tune.
But my guess is that you don't really care and the idea of "going cat-less" is a wet dream of yours.  If that's the case, nothing I, the government, nor anything that anybody else will tell you would change your mind.
A modern, high-flow cat will provide the same muffling effect as a baffled muffler design with none of the flow restrictions that typically make people delete their cats.
If you want an exhaust that ACTUALLY makes more power than stock, here is your recipe:
Scrap everything from the exhaust flange rearward.
1 1/4" primaries with a decent merge angle aft of the factory cat location going up to a 2" primary.
A single entry/single exit 2" 300+ cell high-flow cat mounted below the driver.
2" Straight pipe out the rear.
If this set up proves too loud or too raspy, you can add a resonator after the cat, or a straight through, perforated core muffler in the stock location.
Edited by carfreak85
If I were to need to pass emissions, which I'm not required to do, I'm thinking no converter is going to let my Weber conversion pass. It's likely this car will be driven less than 1000 miles annually.
I do think your prescription for a high flow system is spot on.
