defiance garage Posted July 15, 2017 Share Posted July 15, 2017 Good morning, I am doing an engine swap. I need to know what sensors are required to make in run reliably. I picked up an engine and it has most of the wiring harness still attatched. I a plan to get an ecu but not sure if any particular year is better then other. Then i will find the wiring pin out for that computer and start making my harness. I just want to say thank you for the help in advance. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 15, 2017 Share Posted July 15, 2017 What year is the engine? And for curiosities sake, what are you planning to put it in? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 16, 2017 Share Posted July 16, 2017 All of them. GD 1 Quote Link to comment Share on other sites More sharing options...
defiance garage Posted July 21, 2017 Author Share Posted July 21, 2017 The engine is an early 90s legacy engine. Building a vw baja beetle. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 21, 2017 Share Posted July 21, 2017 Good morning, I am doing an engine swap. I need to know what sensors are required to make in run reliably. I picked up an engine and it has most of the wiring harness still attatched. I a plan to get an ecu but not sure if any particular year is better then other. Then i will find the wiring pin out for that computer and start making my harness. I just want to say thank you for the help in advance. don't make a harness. Strip one down complete from a compatible car. Do you have the intake? how many large connectors to the body harness does it have? If you don't have an intake get one. Preferaby from complete harness donor car to make sure the connectors match. Legacy 90,91 is 3 connector, 92-94 is 2 connector. Or you could run it with any Impreza 2.2 or 95-98 OBD-ii 2.2 or 2.5 computer from Outback or legacy or even 98 Forrester. You just have to get a matching OBD II 2.2 intake. But for the love of god......search.....there is so much info on harness prep and what works for what. Quote Link to comment Share on other sites More sharing options...
defiance garage Posted July 21, 2017 Author Share Posted July 21, 2017 I have the intire engine minus a coil. The harnes is mostly there but has been cut. That is why I was thinking i would have to build from the computer I get to the sensors that are essential to make it run. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 21, 2017 Share Posted July 21, 2017 As I said - all of them. You can't tune those ECU's so for it to work correctly you will have to hookup everything. As said - get a complete harness and strip it. You can't build one because you can't buy the connectors to do so. GD Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 21, 2017 Share Posted July 21, 2017 ASSuming "early '90s" is 1990-1994 and ASSuming you are planning to use the stock ECU and ASSuming you have all the connectors GD is pretty much right, those engines don't have much that they don't use. There's a couple emissions solenoids that wouldn't effect the way it runs, but would throw a check engine light. But it's so easy to just hook them up, just do it right. Everything is mounted to the engine except the MAF and ignitor. 1 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 21, 2017 Share Posted July 21, 2017 You still need alotnof other stuff if all you have is an engine and a cut up harness. Really need to know exactly what year the engine is. 90-91 used different idle control and injectors and they don't interchange and don't work with 92+ ecu. Easiest thing is always to start with a whole dash /engine /ecu harness and cut out what isn't needed for the swap. Much much harder and more expensive to build a harness from scratch. As said earlier there is tons of info on VW swaps and what works and doesn't and what's needed. Quote Link to comment Share on other sites More sharing options...
