vsmith63 Posted July 17, 2017 Share Posted July 17, 2017 I need some help!!! while returning from a road trip my driver side seat heater was on but i never pushed the button for it. That thing is blazing and it's 9in the high 80s to 90 degrees ut side. what is going on with this thing? Link to comment Share on other sites More sharing options...
idosubaru Posted July 17, 2017 Share Posted July 17, 2017 I would disconnect the heater element connector under the seat. You could also pull a fuse if it's not shared with other, or other necessary, components. Owners Manul in glove box will have a section on fuses and should show which one is for the heated seats. Link to comment Share on other sites More sharing options...
gbhrps Posted July 18, 2017 Share Posted July 18, 2017 (edited) vsmith63, Obviously the switch has a direct short, is jammed/welded in the on position, or the wiring from the switch to the heater has a direct short to power. Should be an easy fix to diagnose where the issue is. Broken wires in the seat heater element are the most common issue with seat heaters, but in that case, they won't work at all, or only at a lower heat setting. Edited July 18, 2017 by gbhrps Link to comment Share on other sites More sharing options...
