I misspoke. Its the avls system rather than the vvt syystem
Spun bearing in 2008 ej 25 with avls. Need to remove metal shavings from avls unit on heads. Can it be cleaned out with the avls solenoid connected to the base. If the solenoid needs to be removed from base, how does it disconnect from base.
Edited by steve56
