Spare tire options after 6 lug hub conversion?
Late 70's, early 80's GM thought it would be cool to provide these collapsable, inflatable spares with an air canister to fill it. Thereby advertising 1/2 foot more cubic trunk space.
Probably all dry-rotted by now, if you could even find one... never mind.
Tailgate mount or roof basket would be cooler anyway  B)
Presumeably your current tires are bigger than stock. IMO, a suitably-sized spare (compared to the 4 tires on it), is probably too big to fit under the hood. There isn't even room for a full size stock tire under the hood, so they included a stud to bolt it down in the cargo area.
I'll admit, I've never tried it.
But I know 100% that Subaru built a captive nut into the rear cargo floor of EA82 wagons, and included a hardware kit with the tool kit to bolt the full size tire down after you install the compact. I can't imagine anything oversized would really fit.....
But, I'm ASSuming that we're talking about an oversized tire. I admit I clicked reply before I realized that it might be fairly close to stock sized.
It also occurred to me that we don't know what vehicle he's talking about. He's listed a Brat in the signature.
This is why I don't usually reply if I have to make ASSumptions.
Yes it's a Brat. I've got 14" wheels with 195/70 tires, should have specified that originally. I tried one today and it won't even squeeze even part of the way in. Does the full size 13" actually fit under the hood. I haven't tried one of those. I do have the original doughnut. Guess I could drill the wheel on the doughnut and use it.
Even my ea82 sedan had that in the trunk.
The spare tire space under the hood would be a perfect place to put a compressor and air tank for air horns  :brat:
See, even the brat smiley has it mounted to the tailgate  :D
this thread http://www.ausubaru.com/forum/showthread.php?t=25947
EDIT: you can read through this thread or take this as bleeding edge info
sizes that are known "good" for a matched set of 5 rims/tyres
13's - 185/75/13
14's - 185/70/14
15's- 185/65/15
Known "Bad" for the spare space
195/55/14
185/60/14
195/60/15
Running 195/60/15s can use/fit a 185/70/14 as your spare
(.4mm smaller diameter and a 1.2mm smaller circumference but its
"Thickness" will fit into the space under the windscreen) perfect if you
have 4 alloy pug 15's and a single pug 14 alloy as your spare as you
don't have to worry about carrying a non-alloy-pug set of wheel nuts for
your spare.
running 27" x 14 muddies - use a 175SR13 truck tyre on a steel 13" standard rim as your spare.
NOTE: a lift kit DOES NOT change the depth of the body cavity under the
windscreen - this continues to set the widest a tyre can be to fit unto
the standard spare space.
