osmonxp Posted August 15, 2017 Share Posted August 15, 2017 (edited) I'm trying to find out what is causing my tires and steering wheel to vibrate every time I turn the steering wheel. I replaced the power steering pump and the racking and pinion look fine (no leaks or other visible issues). I also replaced the fluid and bled the system but that did not help. Any help you can provide me with will be greatly appreciated. Here is the video: Edited August 15, 2017 by osmonxp Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 16, 2017 Share Posted August 16, 2017 video not seen look inside the reservoir for bubbles - you may have air being sucked-in. very common problem Link to comment Share on other sites More sharing options...
