wagons Posted August 18, 2017 Share Posted August 18, 2017 So my head bolts are pretty rough. Does anybody have a part number for new bolts? Will I just have to use a thread chaser and clean them up? Can I retrofit different ones?( not logical but still possible) thanks for the input Link to comment Share on other sites More sharing options...
Dee2 Posted August 18, 2017 Share Posted August 18, 2017 I would get new ones. Any parts store should be able to help you. Link to comment Share on other sites More sharing options...
wagons Posted August 19, 2017 Author Share Posted August 19, 2017 No parts stores carry them. Auto zone, O'Reilly or napa. Im hoping for a Subaru part number lol Link to comment Share on other sites More sharing options...
Dee2 Posted August 19, 2017 Share Posted August 19, 2017 this may help http://www.ultimatesubaru.org/forum/topic/82824-does-anyone-know-ea82-head-bolt-part-s/ Link to comment Share on other sites More sharing options...
wagons Posted August 19, 2017 Author Share Posted August 19, 2017 Dee2, you are the man! Thanks Link to comment Share on other sites More sharing options...
scoobiedubie Posted August 19, 2017 Share Posted August 19, 2017 Clean them up with a utility knife. Remove every speck of oil on both the bolt and washer with brake cleaner before reinstalling. Same with the hole and the cylinder head face that the washers contact. Link to comment Share on other sites More sharing options...
Subaru Scott Posted August 19, 2017 Share Posted August 19, 2017 Sorry, no. Clean everything, yes, but the bolts MUST be well oiled for a correct torque reading. Link to comment Share on other sites More sharing options...
idosubaru Posted August 20, 2017 Share Posted August 20, 2017 Yep lubricated. Not so much or in a way that it's squishing out and running down between block and gasket though. Link to comment Share on other sites More sharing options...
scoobiedubie Posted August 21, 2017 Share Posted August 21, 2017 The bolts will loosen if you put oil on the threads. Then you get to take everything apart, over and over again, replacing the cylinder head gaskets over and over again. Link to comment Share on other sites More sharing options...
DaveT Posted August 21, 2017 Share Posted August 21, 2017 To get the torque correct, the threads are oiled, per FSM directions. Never had one get loose. Link to comment Share on other sites More sharing options...
Subaru Scott Posted August 21, 2017 Share Posted August 21, 2017 On 8/21/2017 at 1:07 AM, scoobiedubie said: The bolts will loosen if you put oil on the threads. Then you get to take everything apart, over and over again, replacing the cylinder head gaskets over and over again. Who is feeding you this gibberish? STOP listening to them and trying to spread misinformation please! Thank you. 1 Link to comment Share on other sites More sharing options...
scoobiedubie Posted August 21, 2017 Share Posted August 21, 2017 On 8/21/2017 at 4:04 AM, Subaru Scott said: Who is feeding you this gibberish? STOP listening to them and trying to spread misinformation please! Thank you. I have tried it both ways and know for a fact that the cleaner the better. You will never be able to get all of the oil out of the threads but they will hold position a lot longer and not loosen, if everything is dry. 47 ft-lbs of torque is no problem with dry threads. It is even better to tighten them up, let them sit over night, and come back and retorque them the next day. Link to comment Share on other sites More sharing options...
wagons Posted August 21, 2017 Author Share Posted August 21, 2017 I got new ones ordered, dee2 provided accurate part numbers and match perfect. I know to clean Block with a thread chaser as original bolt holes are gunked up. I also always oil my bolts before installing. Thanks for the help peoples! Link to comment Share on other sites More sharing options...
Subaru Scott Posted August 22, 2017 Share Posted August 22, 2017 On 8/21/2017 at 10:29 PM, scoobiedubie said: I have tried it both ways and know for a fact that the cleaner the better. You will never be able to get all of the oil out of the threads but they will hold position a lot longer and not loosen, if everything is dry. 47 ft-lbs of torque is no problem with dry threads. It is even better to tighten them up, let them sit over night, and come back and retorque them the next day. You know for a fact? That is not a fact, only some crazy theory you dreamed up. Facts have proof to back them up. Where is your proof? Here are facts: Fact: A fastener which is lubricated will turn farther at a given torque vs. a dry one. Thereby drawing the attaching parts tighter together. Anyone can prove this by torquing a bolt down dry, marking it's position, then after lubricating and torquing to the same value, the bolt will have turned further. Fact: Subaru specifies lubricating head bolts upon assembly. The torque spec the factory service manual states is for lubricated head bolts, not dry ones. If you torque it dry, it is NOT TIGHT ENOUGH! Fact: Aluminum threads are very fragile. ANY high torque fastener in aluminum threads must be lubricated or the threads will gall. In my opinion, every fastener in aluminum needs to be lubricated, high torque or not. In fact, I use marine grease on EVERY fastener that goes into aluminum, or has even a remote chance of being exposed to moisture. I've been doing this for decades now. And guess what? None of them ever come loose on their own. So I don't know what it is you're doing to make your head bolts come loose, but it has absolutely nothing to do with lubrication. And again, of course you're free to do whatever you want with your own vehicles, tear em up! But don't get on here giving bad advice like it's fact. You are free to discuss all the theory you like as well. Just make sure to include, "In my opinion", or "I believe" along with it. 2 Link to comment Share on other sites More sharing options...
