WJM Posted June 20, 2004 Share Posted June 20, 2004 Umm....blank post. What year? What engine? what fuel system? auto or manual? 2wd or 4wd? Probably the EGR or evap solenoid switch thingy. Link to comment Share on other sites More sharing options...
WagonBoy Posted June 21, 2004 Share Posted June 21, 2004 I drive an 88' gl WAgon dual range 4wd, and i have this problem, but it only seems to happen when everything else is tweaking at the same time such as the volt meter, speedo sticks, gas guage says it fuller than it is, the temp guage fluxes mostly on the hot side and the clock is dimming and lighting up and changing times randomly, can anyone diagnose this? Link to comment Share on other sites More sharing options...
calebz Posted June 21, 2004 Share Posted June 21, 2004 I drive an 88' gl WAgon dual range 4wd, and i have this problem, but it only seems to happen when everything else is tweaking at the same time such as the volt meter, speedo sticks, gas guage says it fuller than it is, the temp guage fluxes mostly on the hot side and the clock is dimming and lighting up and changing times randomly, can anyone diagnose this?Alternator. Possibly some crappy or loose connections. Link to comment Share on other sites More sharing options...
Airetime Posted June 21, 2004 Share Posted June 21, 2004 Sorry about that, the home computer was not working correctly. It is a 1987 Automatic transmission 4wd gl wagon. Your basic setup. Everything seems to work properly except this stupid light which seems to come on and off whenever it wants to. Most of the time it says on for awhile and then goes off. Where would I check for loose connections? Link to comment Share on other sites More sharing options...
rallyruss Posted June 21, 2004 Share Posted June 21, 2004 I would check the codes first. spfi I assume? connect green connectors and count the blinks. Link to comment Share on other sites More sharing options...
Airetime Posted June 21, 2004 Share Posted June 21, 2004 Stock OE, I think that it is carbureted not injected but will double check tonight. Gotta make it easy for me you know? I would check the codes first. spfi I assume? connect green connectors and count the blinks. Link to comment Share on other sites More sharing options...
Numbchux Posted June 22, 2004 Share Posted June 22, 2004 I beleive there is a writeup on reading codes in the Ultimate Subaru Repair Manual, and you should be able to read the codes even if the light is not on (they store it to memory). the computer is under the steering column, take of the panel (5 or 6 screws), turn on the ignition (engine need not be running), and count the long and short flashes (long = first digit, short = second digit). then look it up. my haynes manual has all the codes if the repair manual doesn't Link to comment Share on other sites More sharing options...
WagonBoy Posted June 22, 2004 Share Posted June 22, 2004 calebz, should I replace the Alternator after checking all connections and problem persists? I could probably order one from NAPA or go to JY, which is my best bet? Link to comment Share on other sites More sharing options...
