drakehale33 Posted August 21, 2017 Share Posted August 21, 2017 Hi guys, My 99 legacy has in the last couple of days developed an issue where everytime it upshifts from 2-3 it will free rev for a second and then engage. Happens everytime whether car is hot or cold. I've drained and filled with atf hp and it hasn't made a noticable difference and it doesn't give any codes using the 4eat "secret handshake". I also reset the ECU/TCM. Almost seems like an electric/solenoid issue as it isn't slipping just not executing the 2-3 shift properly. Any ideas before I bring it to a shop. It's only got 71k so hopefully nothing overly serious. Thanks! Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 21, 2017 Share Posted August 21, 2017 For starters it shouldn't have HP fluid it should have Dexron III. Did the problem start before the fluid change or after? Link to comment Share on other sites More sharing options...
drakehale33 Posted August 21, 2017 Author Share Posted August 21, 2017 (edited) Couple of days before the change. The atf hp is backwards friendly or so I read. It's funny the manual says dex ii or iii the dipstick says dex ii and Subaru says hp. At any rate the fluid seemed to improve all other functions but the issue with 2-3 is unchanged Edited August 21, 2017 by drakehale33 1 Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 21, 2017 Share Posted August 21, 2017 If it has the external spin-on filter you might consider changing that. Seems to me that I read about an issue several years ago with the ATF cooler in the radiator getting partially clogged and causing shifting problems and slipping, but it wasn't a widespread issue. More than likely the clutch pack for 3rd is worn and nothing fluid related will change or fix that. Could maybe be a sticking shift solenoid. A solenoid pack might not be too expensive from a u-pull-it yard, but it means draining the fluid and dropping the pan. 99 was a picky year for transmissions anyway, most have a problem with slow engagement from reverse to drive. usually better off to swap it with a 00-03 trans. Link to comment Share on other sites More sharing options...
