jono Posted August 22, 2017 Share Posted August 22, 2017 I have LED inserts for the high beam inners of the quads and they have been available for service sometimes, other times choosing to go out or rather not switch on when asked of. Of course the lows drop out and if I have highs in the outers which sure I do, they drop out as well.The relay I thought was high beams under bonnet on a bracket with fan? Relays checked out fine. No separate high beam fuse marked in panel. Low beams work fine just dim and makes our kangaroos but hard to pick out in the dark . you are only gonna see the orange of their eyes once a blue moon Link to comment Share on other sites More sharing options...
Gloyale Posted August 22, 2017 Share Posted August 22, 2017 Since subies are ground switched, I wonder if the LED polarity is backwards.....espescially on the outers with hi/lo. you could make a relay bank triggered by the subie wiring but sending power to bulbs with + switching. Honestly I am a bit confused by your description. What excactly is your setup? Link to comment Share on other sites More sharing options...
jono Posted August 23, 2017 Author Share Posted August 23, 2017 Quads but the inners(which are high beam only) now have Chinese 15 LED lamps found on eBay for Landcruisers of similar age. The LED have worked fine for two years until this high beam problem I termittently not work happened. It has now progressed from intermittent to no high beams either use the flash high beams part of switch or normal highway driving high beams on. Wondering if anyone has a diagram for quad lights that shows a separate relay other than the Mitsubishi style cylindrical relays near fuse panel in MY EA81 body style Link to comment Share on other sites More sharing options...
jono Posted August 23, 2017 Author Share Posted August 23, 2017 I have learned to use both wires of existing circuits in subies to ensure relays switch things right☺ Link to comment Share on other sites More sharing options...
skishop69 Posted August 23, 2017 Share Posted August 23, 2017 So either one of the high beam lamps has gone bad and is creating feedback or a short, or your high beam switch is going bad. Link to comment Share on other sites More sharing options...
carfreak85 Posted August 23, 2017 Share Posted August 23, 2017 [rant] Ugh, those "15-LED Chinese" lamps are going to be worse for night vision than your original headlamps. You REALLY should only upgrade to LED 4"x6" lamps from reputable companies who actually design their products for improved night vision. [/rant] Link to comment Share on other sites More sharing options...
jono Posted August 24, 2017 Author Share Posted August 24, 2017 Yes. I think to isolate the LED units first before chasing any goose. Boy ranter are you wrong about the night vision compares to factory lights....well, before this happened!thanks, will come back when sorted Link to comment Share on other sites More sharing options...
carfreak85 Posted August 24, 2017 Share Posted August 24, 2017 Jono, there is a lot more to proper lighting than a simple "eye test". I'm confident enough in that statement that if you send me one of your lamps and I'll provide a stock halogen lamp. If those eBay-specials out perform the factory halogen lamp in terms of proper distribution of light, beam cutoff, build quality, durability or anything except for total lumens produced, I will send you $250 USD via paypal. Link to comment Share on other sites More sharing options...
