the best "upgrade" you could give your car would be a full "tune up" with quality parts
NGK plugs and wires
air filter
fuel filter
PCV valve
New vacuum lines
Complete timing kit (if needed/not done recently)
fresh antifreeze
and an oil change
there are not really any aftermarket "performance upgrades" for these cars.
If you are after "performance" - get a WRX.
  • Like 1
+1 on keeping up with fluids and tune-up parts.
you can make the car feel sportier with suspension upgrades; new struts, heavier anti-sway bars, stickier tires.
and lighter rimes will free-up a coupla ponies and give you a chance to personalize the looks a little. Maybe a lightweight crank pulley too.
most cops don't care how fast you turn corners.
"it's more fun to drive a slow car fast than a fast car slow"
  • Like 2
Hi,
Just 'adding fuel' doesn't do you any good w/out Engine Management (EM).
Are you coming from another brand/background that you have for reference? If you're new to cars in general than there's a ton of info online about upgrading a car's fueling needs, but it's not 'just because'.
The main issue w/the EJ22's  is the lack of tuning options. If yours is in a '90-'94 there are limited options; if '95-'01 basically none that don't require a lot of wiring - harness merging, ECU-swapping, etc.
Do a search on NA-T -turbocharging a non-turbo Subaru  - for info....been done many times and as long you're not greedy it'll run for a long time too. My Link.
TD
Edited by wtdash
  • Like 1
NGK plugs and wires
air filter
fuel filter
PCV valve
New vacuum lines
fresh antifreeze
and an oil change
I've done just about all of these things as well as timed the car myself with the waterpump change
Then you are pretty much done.
there really is no "aftermarket" add-ons for them to increase performance - without spending a truckload of money, of course.
these cars are built for reliability & to some degree, economy, not "performance"
You could look at possibly adding a turbo, but that brings with it a whole host of other issues (and related costs).
Accept it for what it is. If you want "performance" go buy a performance car.
  • Like 1
