Subieguy165 Posted August 24, 2017 Share Posted August 24, 2017 Have a oem fix-a-thread helicoil set and I don't know what the outer diameter is for a tap can someone help me out? Part number - 25648 Link to comment Share on other sites More sharing options...
golucky66 Posted August 24, 2017 Share Posted August 24, 2017 What size if the helicoil for? Like a 8mm x 1.25, 6mm x 1.25. Link to comment Share on other sites More sharing options...
Mike104 Posted August 25, 2017 Share Posted August 25, 2017 (edited) M14 x 1.25 14.30MM drill https://www.thorintl.com/Drill-Sizes-HeliCoils-Metric.shtml Google is your friend! About a 9/16 drill bit Edited August 25, 2017 by Mike104 Link to comment Share on other sites More sharing options...
Subieguy165 Posted August 27, 2017 Author Share Posted August 27, 2017 Well the m14-1.25 is the inner size just can't figure out what is the outside so I can tap the head correctly Link to comment Share on other sites More sharing options...
Mike104 Posted August 27, 2017 Share Posted August 27, 2017 (edited) Check my post above. It needs a 14.30 mm hole size. There are special helicoil taps to thread them into. Description M14 x 1.25 HSS STI Plug TapProduct Specs: For use with: Helical Screw Thread Inserts Use with Internal Thread Size: M14 x 1.25 Material: HSS (High Speed Steel) Compatible with: Helicoil, Recoil, Perma-Coil, Powercoil or any other standard Helical Screw Thread Inserts Our Screw Thread Insert (STI) Taps are used specifically to create threads for Helical Thread Inserts. STI Taps are oversized so the thread produced will accept a Helical Wire Insert of the same nominal size and pitch - meaning the hole created by the Tap goes back to the original dimension allowing the original fastener to be used. The "Plug" style Tap is ideal for starting or tapping a through hole. The Tap can be used and the Helical Insert can be installed in most materials including aluminum, magnesium, cast iron, carbon steel, stainless steel, and plastic. Proudly made in the USA. You need an M14 x 1.25 Screw Thread Insert Tap https://www.amazon.com/Metric-Right-Thread-1-25mm-Pitch/dp/B00N1HULOO Edited August 27, 2017 by Mike104 Link to comment Share on other sites More sharing options...
Gloyale Posted August 27, 2017 Share Posted August 27, 2017 Well the m14-1.25 is the inner size just can't figure out what is the outside so I can tap the head correctly it won't be a standard tap. you need one designed to be used with that size helicoil. Ussually they are included in the helicoil kit for each given size. Link to comment Share on other sites More sharing options...
Gloyale Posted August 27, 2017 Share Posted August 27, 2017 Well the m14-1.25 is the inner size just can't figure out what is the outside so I can tap the head correctly m14? on the head? what the hell part are you trying to tap? I can't htink of anywhere on a subaru head that uses m14? unless you are meaning the spark plug hole. If that's the case DO NOT use a helicoil or other helical insert. You need a full sleeve "spark plug hole" repair kit. might be better off trying to find a good core head to use rather than trying to fix. It can be tricky on those deep recessed holes and if you screw up you will have spark plug rocket out of the hole. Link to comment Share on other sites More sharing options...
Subieguy165 Posted September 20, 2017 Author Share Posted September 20, 2017 Fixed sparkplug hole finally Link to comment Share on other sites More sharing options...
dumpstar Posted October 19, 2018 Share Posted October 19, 2018 These inserts have an: Outter diameter: M17 x 1.25 pitch Inner diameter: M14 x 1.25 pitch If you get the OEM M14 1.25 Fix-A-Thred kit, that tap is the correct size to tap the spark plug hole-- but it absolutely will not fit down into the spark plug hole with a socket around the head of the tap (it's simply too fat). I had a smaller diameter deep socket welded to the top of the head of the tap at a local machine shop for $20. Then i was able to use the welded on deep socket's drive hole, a ratchet, and an extension to turn the tap. Link to comment Share on other sites More sharing options...
