Superpro Kit numbers
Hello, I've got a set of front control arms off a 89 XT6 for my five lug conversion with busted bushings and I'm trying to figure out if I need the 24mm bushings or 28mm. I tried to measure then but it doesn't really match up.
  • 2 weeks later...
Bumping this thread because I'm also in the same boat. Need new control arm bushings for my 5 lug swap.
Some old threads say the ea82s will fit some say they don't. I wonder if early EJ legacy/impreza has the same size bushing
  • Like 1
  • 2 weeks later...
I haven't yet, but that's what I intend to order.
It would appear the Loyale/gl trailing arm is the same bushing as the xt6 front.
The overall width of the sp1144k kit when installed will be 2mm wider then stock. I have not yet confirmed that this will fit, but it should.
Edited by Vkbikes
